Cross over freq Question?
Username: Morganrm15
If a receiver already has good cross over management and bass management why do DVD players such as the pioneer 578 have speakert setting etc.??
Do you have to set both? I'm very confused
For multi-channel music, you need to use the DVD player's bass management since few receivers perform bass management on the analog inputs.
If you use the digital connection between your DVD player and receiver, your receiver will handle the bass management, and the bass management in the player will have no effect.
