Doubt about interconnection
Username: Argento
Post Number: 68
I have a doubt about an equipment interconnection.
If I want to connect a receiver with pre-outs to an integrated amp or a pre/amp, How should I do the connections between then?
Thanks for the help.
Username: Argento
Post Number: 70
I want to use the equipment for music (the integrated or the pre/amp) and for movies (the receiver) without change connections and using a single pair of main speakers.
Which is the right configuration?
Username: Project6
Post Number: 1726
You want to use a single pair of speakers with 2 amplifiers???
You still need a switch to go back and forth between the amplifiers/receivers/integrated amps.
Username: Argento
Post Number: 71
Berny says:
Yes, that's the idea.
Would I connect the mains pre-outs of the receiver to an AUX input of the integrated or pre?
Username: Argento
Post Number: 72
Of course, the mains speakers should be connected to the integrated or amp.
