Multiroom receivers
Bryan Sayer
I want to get a multiroom receiver to use for both home theatre and for music/radio in three other rooms. I've seen a Sony and a Yamaha advertised with multiroom capability (meaning two different outputs from different inputs). The other rooms will have impedence balancing volume controls (I use the Pass-Seymour system) so all I need is to pass one output to the audio distribution module while the other set of outputs is for the home theatre.
Are there any reviews of receivers devoted to multiroom capabilities, or does anyone have experience or recommendations?
Username: Topher
Post Number: 9
I have an HK 325 & the multi-room facilities work great, but I can't find a place that sells the A-Bus equipment, & after using it a year, I realize that video out for zone 2 is a must, much like the Yamaha 2400 has.
