Paradigm Studio 60 v3 vs Paradigm Signature S2?
Audiofreak
I have enough budget to buy either the floorstander Paradigm Studio 60 V3 or the Bookshelf Signature S2. Which is about the same price.
Anyone has listened both?
I beloeve the Studio 60 has better base extension but the S2 has better all round imaging, clarity, highs etc.
Which one would you advise? 70% music (all sorts) and 30% HT. Going to match either with a subwoofer.
OnimushaLord
Since u r matching with a sub, I believe the Sig S2 would be a better buy. The only downside is u have to match the S2 and sub properly.
