Computer PS powered car amp
Username: Myleftnut
hey, i was wondering if anyone can help me wire up some AT PSes because i cant get my hands on any ATXs and i cant get the PSes to start up. much help is greatly appreciated
Are you sure you want to do this?Most car amp consume more current than main-powered amp as its supply voltage is only 12V.You need to make sure you AT/ATX PS can supply more than 20A or higher.Otherwise before you switch on the whole thing,you better shout:"Fire in the hole!"
