Bronze Member Username: Mike_anthesCanton, SD USA Post Number: 44 Registered: Aug-04 | k guys i need a good PRO audio system that will make you feel the sound on your chest in a gym, i know this is hard but i really want this. im kinda a more car audio guy but want to do some djin around our area for dances, weddings,etc. will this system here be HEARD in a gym??? 4 of these- 2 of these-http://www.steelsound.com/product.cfm?ProductID=94 and for amps i was thinkin bout goin with all Crown amps... would this be good??? already gota mixer and eq and everything... |
Gold Member Username: Project6Post Number: 1540 Registered: Dec-03 | Crown amps are excellent for heavy duty professional use. |
Bronze Member Username: Mike_anthesCanton, SD USA Post Number: 45 Registered: Aug-04 | yea i know, thats why i picked them, but will this system work VERY WELL in an entire gym? |
Gold Member Username: Project6Post Number: 1545 Registered: Dec-03 | Absolutely, but your problem does not lie in the equipment but the environment. Being a car audio guy you should know the challenge when you are dealing with acoustics in certain rooms. Sounds tend to get amplified in the gym so you will do fine, plus with those horn loaded drivers, you may be able to coax some blood out of a few ears![]() Experiment on the placement of your speakers, from my experience, the low frequencies (da boom) tend to cancel each other out when all four speakers are facing each other. |
