Need small speakers for my Marantz
Username: Allen_in_ky
I have a Marantz 2385 and need a couple of speakers to go with it. They are going behind a bar (not much room) so they need to be a smaller type speaker. Something I can mount on a wall or in the corner would be nice. Though small they need to be able to handle the power of the Marantz. It will be primarily for listening to CD's and radio....no theater hook-ups. Also looking for a good mid-priced CD player to go with it all. Any suggestions would be appreciated. Thanks
Username: Chuck_m
Cincinnati
Post Number: 8
Allen - I believe the 2385 is one of Marantz vintage, hi power, 2-channel receivers, right? My suggestion would be a pair of Axiom M3ti's. Fairly small, very musical, acceptable bass for the size, good price. Check out axiomaudio.com. A couple more - Athena SB2, Monitor Audio B2. Have fun!
