H/K avr230 & Pioneer VSX-1014TX
Username: Sinkdrain
Post Number: 13
Ok, I was looking at the H/K avr330 but now my budget has been slightly slashed. The avr230 is now in the $300-400 (street price). I see there is a Pioneer VSX-1014TX out there for the same price, feature packed. Have any of you heard these two receivers.
Now that I am in the $300-400 range I am worried that their are better choices than the H/K for my Athena speakers.
Username: Bleustar
Pensacola, Florida
Post Number: 121
Gererally speaking the entire AVR line from HK(leave out the AVR7300) sounds the same. The feature set from the AVR230 to 330 will be the only "real" difference.
Username: Rh1
Post Number: 179
Both of those receivers are well worth their respective price. I think you will do fine with either one. I have not heard the 1014tx, but i have heard the 914 model and it was quite pleasing for a low budget receiver. I think it's certainly better than Onkyo, Yamaha, and Sony's receivers in this price range. I would say that features would be the deciding factor in those receivers you mentioned with a slight edge to the 1014tx IMO
Username: Rh1
Post Number: 180
Have you tried finding the AVR 330 online?
Here's one for $369
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39794%26item%3D5724052220 %26
