NAD t763 A/V receiver VS NAD T163
Ben Hogg
Hey there,
i own a NAD T763 receiver and im wondering what the differences are between the pre amp side of the T763 and the T163 pre amp, i'm wondering this because im looking at getting a power amp and would like to know if i should buy the T163 and use it as a preamp and not the t763
Thanks
Ben
Username: Gatt767
Theres not alot of difference between these 2 products! The only difference that i can see is that no amplification is interfearing with the digital side of the Processor.As regards to DSP and Dacs in use, both models use the same components. The Purist will choose the T163, others will go to the receiver as the cost is much more lower!
