Connecting Xbox 360 to hdtv ready television
Username: Griff1990
Ok so, I've had this old Hdtv ready television just sitting around for quite a while now getting no use. I recently decided to hook my Xbox 360 up to it instead of the standard def tv it is hooked up to atm. However, the hdtv ready tv does not have a hd tuner I was wondering if I would still be able to play games in hd despite this.
Username: Basshead86
Central Florida
Post Number: 10791
you need the HD tuner for receiving OTA broadcasts from cable or satellite companies. You should be fine. :-)
Need to Register?
Forgot Password?
Enable HTML code in message
