Xbox360 question pls read
Username: Jamesh
Uk
hi guys can any one tell me how much difference there is in xbox360 hd and not hd as im really interested it seems all the magazines that rate these xbox360 games are playing on hdtvs and in all honesty im from the uk and i dont think many of us uk folk are gonna have a hdtv so we will be stuck with the old crt but does the 360 still look good on this when games are played or does it jus look like a normal xbox plays on screen
many thanks
james
Username: Dsj04001
HDTV or not the 360 looks sweet and is definately worth the upgrade from the old xbox in my opinion. But, if you want to get the most out of your gaming experience HDTV is the way to go because it makes it look even more vibrant and more real. But if and hdtv is still not an option, I would still get the 360. Afterall, it's looking like the revolution wont support 1080i so that just shows the next gen consoles will still look good on sdtv's.
Username: Jakedasnake
Knoxville, TN USA
I have a '96 36 inch magnavox, and i cant get my 360 to play on it, can anyone tell me why?!?!?!
Username: Project6
Post Number: 7789
How are you connected to the TV?
Username: Stilwell
Im pulling my hair out with this! I've bought myself a 32inch philips hd tv the only problem is i only have a dvi-i input and my x-box 360 does not support this. I bought a dvi-i to RCG converter but now i have a brilliant picture but no sound. I've hooked up all cables (yellow and white) audio and (red green blue) for the picture. Ive also changed the setup programs on the console in relation to HD and audio.
Please help : )!!!!!!!!!!
Username: Ju1cyfru1t
Post Number: 19
Jake,
I know this is a month and a half late, but check the end of your video connector that actually plugs into your 360. There is a switch that is easily changed when plugging it in. It has two setting (HDTV and TV). Make sure it's in the right position.
Scott,
Yellow and white are not for audio (yellow is for composite video). Audio is red and white, along with your r,g,b (component).
Username: Brick86
For the guy with the problem... you may need to buy a rerouter if your using hd.
Username: Brick86
Username: Project6
Post Number: 8450
A rerouter????
Username: Brick86
Post Number: 7
Yeah. It's a box where you connect all inputs for A/V. Sometimes just hooking it up to the T.V. doesn't work. Please no more questions. Do some research.
Username: Project6
Post Number: 8488
That is not a rerouter...that's a switch.
Username: Tru_wpg25
WINNIPEG, MANITOBA CANADA
DO NOT buy a 360 if you dont have a high dif tv... There would be no point to play the 360 on a crt... Let everyone know this!
Username: D_singh
Post Number: 127
What are you talking about? Games for the 360 cannot be played on the original XBox. No point my foot...
Username: Dustin3
Tigard, OR U.S.
Post Number: 3971
lol. there is not that huge of a difference T.R.U. there is a little but not that huge. the 360 is good for anyone that wants a good system
Username: Dustin3
Tigard, OR U.S.
Post Number: 3972
games on xbox can be played on 360 tho
Username: Lunaticspartan
hello i got a non lcd philips tv i connect my 360 with y pb pr component the games graphics look cool but within an hour the screen show blue dots can i fix them .......
Username: Abba0512
Hi
The arcade games that came with my Xbox 360 premium ( Outpost Kaloki X and Wik: Fable of Souls) well i deleted them off my hard drive when i was doing a clear out but then realised that i actually wanted the games. Is there anyway to get the back, i have tried to see if there was a "download again" option on the games but there was not one there so any help would be appreciated.
Thanks in Advance
Need to Register?
Forgot Password?
Enable HTML code in message
