Need help with my XBOX!!!!
Username: Newtofta
Post Number: 63
The problem that i am having with my XBOX is that i can play it for about 30 to 40 mins and then it says disk cannot be read. I have already cleaned it and the games ive tried lately have all been brand new ones. Any suggestions?
Username: Sheriff
Post Number: 272
Buy a 360.
Username: Deadhorse
Post Number: 64
Or replace your DVD drive, I did it last year for $40, worked a treat.
Username: Newtofta
Post Number: 125
do i need a certian DVD drive?
Username: Deadhorse
Post Number: 66
There's a few different manufacturers, I got a Phillis and I've never had any problems.
Here's a link to a place that sells them but you could probable get it cheaper on Ebay or Amazon, just make sure it's brand new, not used or refurbished.
http://www.richspsxparts.com/xbox.html
I think there's detailed instruction on how to safely replace one on here too.
Username: Newtofta
Post Number: 126
thank you....i appreciate it....will check it out.
Need to Register?
Forgot Password?
Enable HTML code in message
