Xbox 360 - media center
Username: Dmg025
Post Number: 7
so what exactly can i do with my xbox and windows media center pc? I don't have the internal tuner card, so that eliminates the recording of tv. can i do anythign else cool? i can already play dvd's on my computer so....
And how do i run my xbox360 through my computer sound card. I have audigy 2 zs.
umm i have the xbox 360 and i have done what you have done really get a network cable plug it in the back of the pc and the xbox download windows media connect for the xbox 360 you will find it on the xbox website and install it when that is done well the installation menu tells you what you can do LOL so thats what i did anyway its cool if you do it !! trust me its worth it!
Username: Project6
Post Number: 6147
Charlie??? Is that you???
Need to Register?
Forgot Password?
Enable HTML code in message
