Need some major help!!
Username: Mebcitadel
Ok. So I have a
Samsung T220HD Monitor (VGA, DVI-D, HDMI ports, Component input)
XBox 360 (No HDMI port)
ASUS G51JX Laptop (Only HDMI port)
and perhaps most importantly,
Klipsch Pro Media 2.1 Speakers
I would be HAPPIEST to have these all set up together, where sound was coming out of the speakers from the XBox 360 and the laptop at the SAME TIME, but I know I might have to either:
1. Swap the audio cable back and forth which I guess I'm ok with
or
2. Have no wire switching ever (awesome) but sound and video switches over with the press of the monitor input button.
Can anyone at all help me with this situation?! I know my hardware for the most part but I don't understand cable setup!!!! I've never even used HDMI before!
Username: Ieee488
Post Number: 428
You cannot have sound from the laptop and the XBox 360 going to the speakers all at the same time. It will sound like a mess.
Are you sure your XBox 360 doesn't have a HDMI port?
You'll need an audio switcher.
Need to Register?
Forgot Password?
Enable HTML code in message
