OSD Main Menu Locked
I have an older Micron Electronic monitor where when I press the menu button it bring up a message saying the "OSD Main Menu Locked". Does anyone know a way to get around this?
Username: Fiberoptics
i found the same problem in samsung monitor
syncmaster 551v :S
plz any one can help us ?!
Harald
At least for Samsung try this:
Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
To re-lock it (to prevent accidentally changing the values) do the same again.
HTH
Username: Ryleigh
My new flat screen Magnavox says the same thing, and I tried holding the menu button down, and that just didn't work.... Any other suggestions???
Username: Appzalien
Cleveland, Ohio US of A
Post Number: 123
Every manufacturer has its own way of locking and unlocking the menu, for the best advice, you guys need to go to the support section of the manufaturers site. Send an e-mail if the FAQs or knowledge base don't help and in a couple of days you should have an answer. These guys want you to buy their products and will usually bend over backwards to help.
Need to Register?
Forgot Password?
Enable HTML code in message
