VGA Adapter for Component Video
Username: Reyes
Okay I only have a vga port on the back of my computer and rca plugs on my vcr. I bought a vga to rca out converter and hooked everything up. ALl seems to be hooked up right. However, the computer will not detect the tv as being there. I have tried all kinds of ideas. Please help. Thanks. I have a dell inspiron 1150 with a Intel 2 extreme graphics card.
Username: Illuminator
Post Number: 2903
Have you enabled the VGA output? Normally there is a button called 'Fn' between the 'Ctrl' and 'Alt' keys on your keyboard. You press the 'Fn' key with another button at the same time (usually F5 or another F[number] key) and it should turn the VGA on.
Username: Reyes
Yes I have the screen goes black for a second, but still nothing on the tv.
Post Number: 2908
I need to see the exact VGA-RCA converter you're talking about. Can you link me to a product page?
Username: Reyes
I bought it off of ebay, because I couldnt find it anywhere else online.
http://cgi.ebay.com/NEW-VGA-to-TV-CONVERTER-S-VIDEO-RCA-OUT-CABLE-ADAPTER_W0QQit emZ9713474008QQcategoryZ41999QQrdZ1QQcmdZViewItem
Username: Regalado1
Post Number: 8
You might be in the same boat as myself. Check out this transcoder. It changes your VGA output to component. http://sewelldirect.com/pc-to-tv.asp?source=yahooshopping
Also check out the other post "Gateway to Mitsubishi"
Username: Reyes
Well the cable that i am using is converting the vga to component.
Username: Regalado1
Post Number: 9
How do you know it is. Have you went into the display properties/settings/advanced and changed the monitor?
Post Number: 2916
Ahh, you're both using VGA to composite? Yeah, I'm fairly sure you would have to have the TV-Out function on your computer.
Though tell me how it works out if you just hook it up to the TV without doing anything. I haven't used that adaptor before.
Username: Reyes
I do have a tv out function on the computer because in my graphics card it says television capabilties. I have also looked for the second monitor in display properties it just doesnt pick it up
Username: Reyes
Okay so I bought this:
http://www.sat-depot.com/satweb/htm/about/vhdc300_vga_component.html
The computer now recognizes that there is a second monitor. It allows me to output to the tv. However, the tv screen goes black and and there is nothing there. I tried lowering the screen resoltion, but that did not help. The fact that the computer recognizes the second monitr, tells me that the connection is good.. HELP PLEASE.
Username: Boyce
Post Number: 68
How can you hook it to you VCR? It is a VGA/component video (Y Pr Pb)= (red blue green RCA) * adapter, but your VCR is componsite input only (yellow RCA).?
Username: Reyes
Post Number: 7
A friend advised me that it wouldnt matter??????
Username: Reyes
Post Number: 8
OKay, I finally got something that will work. Here is the problem though. I need to change my settings from Pal to Ntsc. I can not figure out how to do this. Please help.
Username: Luqe
Post Number: 16
hi
i have toshiba laptop and i forget its pw its a power on pw i think bios or system pw sorry i dont know wts its acc called anyway, if any one know how to remove this pw
Username: Elmagico
Post Number: 25
you need to jump a chip inside the board reseting the bios.
Username: Dracon
Post Number: 7
I think that reseting bios wont help in toshiba laptops - but I might be wrong.
Post Number: 4800
The chip thing doesn't work anymore.
Contact the manufacturer.
