Digital OUT connection on my sound card
I have a sound blaster Live! value card I believe and the DIGITAL OUT plug on the back is a 1/8" typical stereo audio cable.
I have a new Sony receiver. I want to connect my sound cards digital OUT to the sony receiver digital in however I don't know what sort of cables I need to buy as most things I see posted talk about having RCA digital outs on your sounds cards (not mine!! :-) )
Also will regular mp3 files playing on my PC be considered "digital out" and go into my sony receiver?
Username: Vermiciouskanid
San Antonio, TX USA
Post Number: 9
The digital out on the SB Live is a spdif (spuh diff). which IS a typical mini plug. The only difference is that it carries a digital signal for 2.1, 5.1 or whatever and resolves at a single RCA plug (usually color coded orange). As long as your receiver has a coax digital input, you're ready for the big time.
Oh yea, the cable can be had at BB, Radioshack or CC. Much luck to you.
Web Hosting and E-Mail + free trial
Need to Register?
Forgot Password?
Enable HTML code in message
