Is it possible to use computer subwoofer in the car ?
Username: 3lo
i want to know is it possible to use computer subwoofer in the car. since i dont want extremely loud sound, all i need is nice bass. how hard is to hook up something like logitech z2300.
Username: Zulkir
U.S.A.
Post Number: 11
home subs work off of 220 or 120v cant run them off 12v unless you use a transformer to step up the voltage.
Username: Zulkir
U.S.A.
Post Number: 12
and even if you got a transformer you need a dc to ac power converter aswell
Need to Register?
Forgot Password?
Enable HTML code in message
