Use Camera only To Delete/Rename Photos?
Username: Tafkam
Texas
Post Number: 168
Hi, just a couple of dumb questions but this is only my second digital camera (first is an ancient HP) but I read somewhere that it is not good to do any manipulation of the photos from a digital camera directly from a PC, as opposed to doing it with the camera. I have a Sandisk 12 in one and I put the Sony Memory stick in there to download, change, or whatever) With my old camera (an HP that used a Compact Flash card) I used to rename, cut, copy, whatever without any bad result. My new camera is a Sony W-7 and so far I have done some renaming, etc with the PC but am I ok here?
I never did have any negative results with the old camera and using the PC to manipulate the photos, but I just wanted to make sure it is ok with this new one. I do know that you have to format the memory card only using the camera not the PC so that is not the issue. If I need to delete, rename, copy, cut, etc is there any harm in using my PC to do this?
Second question, the Sony I now have is 7.2 MP, and I have read somewhere that in reality after about 5 MP the photo quality is only noticeable if you are printing photos over 4x6 in sixe. Since the printing I do is only 4x6 or smaller should I set the camera to a smaller quality than the 7.2 to save space on the card?
Any help would be greatly appreciated
Thanks
Mike
Username: Project6
Post Number: 3158
There is absolutely no harm in using your pc to do any manipulation. That is the purpose of digital pictures and a pc:-)
And no, do not reduce quality just to save space on the card. You never know what type of pictures you will be capturing. Just get larger capacity cards.
Username: Tafkam
Texas
Post Number: 169
Thanks, just making sure!!
Username: Tafkam
Texas
Post Number: 170
By the way, it was the thread on the Olympus "smart cards" that have a panoramic feature built in, and problems arise when someone uses the PC to delete photos, that is why I was asking the question about this. I kind of skimmed the thread and did not realize that apparently this applies only to the Olympus cards, so it does not apply to me.
Username: Project6
Post Number: 3181
Yup, I read that thread, too. I use a stitching tool if I want to do a panorama shot.
