How i transfer moviesfrom camcorder to pc
Username: Hamme
Pakistan
i have panasonic NS-VS50 camcorder it also have pc link cable and software also name
DV STUDIO 2 but this software only downloads still pictures from camcorder, please tell me how i can download my movies from camcorder.
Hedman
my DV Camcorder (Panasonic NV-GS22) Is recognised by my personal computer, however, when I try to get the data to transfer to my computer all that is displayed is pure black, nothing else! And it's not the lense cap lol that most people seem to ask me coz I always check. The same problem occurs when I try to use it as a webcam! Eny1 have suggestions?
Daz
Make sure the camcorder is set to record mode and not playback
I have Identical problem to you Hedman!!!
But my cam is the panasonic NV-GS17
Did you ever get it working?
Username: Venki2154
i have recently buyed the sony handycam HC42e model . i m trying to send the video recorded in tape to pc but it is saying tht pls insert blank CD but i have did same thing and i cant copy the video to pc pls help in these issues .
Thanks a lot in advanece
Username: Project6
Post Number: 4384
How are you connected to the PC?
I am just a layman but have computer knowledge. My interest is to convert the video recording on
the sony Camcorder to PC and burning on the CD
as well as editing with background music can you suggest guidelines to this
Username: Project6
Post Number: 5318
What are your Camcorders capabilities?
Does it have a firewire output or a DV output jack?
Does your PC have the ability to capture videos via Firewire/iLink/DV/IEEE1394?
Do you have a video editing software?
You need all of these and once you have them we can start.
Do not bother with USB.
Jees
Transferring Video from Camcorder to PC
http://www.jakeludington.com/dv_hacks/20051121_transferring_video_from_camcorder _to_pc.html
Need to Register?
Forgot Password?
Enable HTML code in message
