NEW: No reaction
Kaeli
My Nikon camera suddenly has no reaction when connected to my computer. Please Help. I don't know what to do.
Username: Project6
Post Number: 4280
check the cable connecting the camera to the computer. Those things go bad really fast specially if you constantly plug them in and out. It is better to get a memory card reader that is permanently attached to your computer.
Kaeli
What if the cable is ruined? How can I find a new one?
Username: Project6
Post Number: 4282
Take it to any shop that sells computers and you should be able to find the same cable.
Kaeli
Really? Even though like all digital cameras have different cables?
Username: Project6
Post Number: 4336
Yes.
