Cable TV
joaopereira333
Is it possible to build an antenna and a wide band amplifier (50-900 Mhz) that could intercept and use the very small signal iradiated by a neighbouring TV cable (from a very shortdistance of course)? It wouldn't be really honest, but...
Username: L20109
Well, i think that is possible. I have Satellite TV at home and i could get pictures of some
channels using an indoor aerial installed a few meters from the external aerial plug!
Username: L20109
Who is your cable operator?
Username: Danielsun
I broke off the connector to the antenna/cable analog input on my tv. is there another way to hook up my cable. It has an antenna digital input jack and composite inputs and component inputs. Can I hook up to any of them to get a picture?
Need to Register?
Forgot Password?
Enable HTML code in message
