Does this cable exist?
Username: Labelthief
i need to plug these into my computer monitor
http://i46.tinypic.com/dpv4na.jpg
but i only have a dvi-d and usb ports on my monitor. is there a dvi-d to these cables (i think they are composite?) adapter?
Username: Mheath8663
Post Number: 35
It looks like you're trying to connect component video and L/R audio. If so, you won't find a simple cable that will work. This will need to be an analog to digital conversion. I've seen converter boxes that go from component to HDMI. You might also find one for DVI. Try looking at tekCABLE.com. They have a large selection of items like this and are reasonable priced.
Post Number: 36
Need to Register?
Forgot Password?
Enable HTML code in message
