Need help with speaker inputs!
Username: Geargff
Hello, i have some speakers from a friend that have an input like this http://i46.tinypic.com/2yy4cut.jpg
http://i46.tinypic.com/i6a5gj.jpg
I am wondering if there is an adapter for these to an RCA or maybe 3.5mm. If not, can anyone help with maybe how to wire them? The problem is i think they have power and sound on this wire, because there is a + and - on the plugs.
Thanks for any help.
Username: Guile42
Manila, Main Philippines
there are some adaptors you can find on it, just go to some japanese electronic suppliers. probably on elec hardwares also
Need to Register?
Forgot Password?
Enable HTML code in message
