Coaxial to RCA? How...
Username: Aoliver
Michigan USA
So I've searched the archives and all the links are old. I really just need a simple solution.
My problem is that the old threaded coaxial jack on the back of my tv has been destroyed. I still have the RCA ports though. I need someone to tell me how to convert coaxial to RCA.
Thanks.
Username: Mheath8663
Post Number: 14
Adam,
It appears that you want to take a Cable/Satellite TV signal via coax and convert to RCA (audio and video). I don't think a simple cable will do this for you. You'll need a converter box. The best solution may be a cable converter box from your cable provider.
If I am wrong on this assumption and you are just looking for an RCA to F-Type adapter like this
http://www.findacable.com/catalog/27313.jpg
You can find it at
http://www.findacable.com/servlet/the-48/RCA-MALE-TO-F-dsh-TYPE/Detail
Username: Rainnaunseque
Post Number: 29
no need
Post Number: 30
no need
Username: Donnie1973
Post Number: 3185
just a vcr will do
Need to Register?
Forgot Password?
Enable HTML code in message
