remote control
Username: Mlbr
Morphett Vale, South Australia Australia
Hi does any one know where to obtain a remote for a teac digital terrestral receiver model DV-B240 i have a couple of universal remotes but cant get to work ( cheap ones )I have tried numerous online suppliers but to no avail.
I live in Australia so dont know if the model is aviable elsewhere.
hope somebody can help
regards Mal
Username: Glasswolf
NorthWest, MI USA
Post Number: 12382
www.logitech.com
look at the Harmony remote line, programmable remotes, look at the "Does it control my device?" part and put in your make and model of Receiver to see if it has preset codes for that AVR.
I use the Harmony 1000 partly because it was one of the few that had commands already set for my old panny laserdisc and denon tape deck, for which I no longer have the original remotes.
Need to Register?
Forgot Password?
Enable HTML code in message
