Help with Induction heating for steam
Username: David1234
Hi,
I'm working on a project that would require the ability to heat water into steam via electric induction, preferably DC or via AC converter if necessary.
I'm thinking a monotube design with an induction coil surrounding it that could produce steam from 2 quarts of water in say 30 seconds or less.
Anyone here have experience with that kind of design?
Thanks,
Username: Project6
Post Number: 14663
How is this related to Power Conditioners?
Username: Marina_meggy
Definitely use a single tube. I would use one with vanes on the inside to maximize surface area between the water and the metal.
Need to Register?
Forgot Password?
Enable HTML code in message
