Using the Available Space for Your Home Theater Room
Username: Nency
Post Number: 108
Setting up your home theater can be time-consuming, but it's something that you also need to give careful thought to. Besides the obvious things (type of HDTV to buy, placement of your TV, where you want your theater located, type of home theater lighting to use, etc.), you also need to consider your home theater seating layout.
Why is home theater seating layout important? Well, you want to be comfortable in your home theater. While how comfortable your seating is does affect this, viewing angle, the space between seats and the ability to recline your seats also affect comfort.
Generally, before you go out and buy your home theater seats, take a look around the space that you have. Is it really big enough to fit home theater seats with risers (risers allow you to create rows that are higher than the one in front of it like real movie theaters)? Or, is just big enough to fit a couch? Your budget will also affect these decisions.
You also need to consider optimal viewing range. If you have a HD television, your seats should be as far back as three times the width of your screen. This way, you and your guests won't be straining their neck or eye sight to watch the television.
Username: Magfan
Post Number: 1961
Ah, I wish I had the space. The kind of theater needing and deserving such seating would have to be at least 500 sq. ft. to start. Yeah, maybe 20x25 feet.....
You would have to be stinkin' wealthy to build a proper room needing riser / stadium type seating. a huge screen with projector and the sound system with multiple subs and the separate electric service.
Add in a couple grand for the popcorn machine when your done!
Username: Nency
Post Number: 111
If you do plan on having actual movie theater seats, you need to allow for aisle and arm space, which can range from 20 inches to 2 feet apart. Your aisle should be approximately two to three feet wide on either side and behind each row so that people can easily access the seats. You don't need to have a huge aisle behind the back row.
Need to Register?
Forgot Password?
Enable HTML code in message
