Centre Speaker L/R single output on amp
Username: Slaytan
Australia
I have an old Pioneer VSA-530 amp and have never had a centre speaker hooked up to it, I have just brought a centre speaker and want to know what speaker wire setup I would need to connect from a L/R single output which looks like an rca female connection to the speaker which has 2 binding posts?
Username: Jan_b_vigne
Dallas, TX
Post Number: 10025
RCA's feed line level signals which are meant to connect component to component. They cannot drive a loudspeaker directly. From what you describe, you will need an amplifier for the center channel and the speaker will connect to it. Does the receiver have Pro Logic surround?
Username: Slaytan
Australia
Its Dolby Surround and the output has 30 watts rms running out of it , doesn't need another amp connected to it. Its an AV digital surround amp if thats any help. I have lost the manual for it,so I'm in a spot of bother, gonna strip an rca lead at one end and try it, if it doesnt work then I'm gonna buy another amp and stick this one on ebay.
