PC VGA or DVI out to TV RGB SCART
Username: Momo2oo2
I know (for the time and research lost in the process) that it must be complicated, since in 2 days of googling and reading articles and boards haven't found much about this subject.
What I want is connect my ATI Radeon's output (D-Sub 15 or DVI) to my TV's RGB SCART to get better image quality, since the Radeon's TV-OUT is S-Video and the image quality is low.
From what I have researched, the D-Sub output's signal is RGB sync, the DVI I have no idea; and what I need in the TV input is RGB "?" (dunno what). How can I get this?
In 2 days I've read a LOT about video signals, video standards, cable standards, etc., and can't get an easy solution.
The two options I have (apart from the yellow RCA that goes with the stereo audio) are:
D-Sub 15 to RGB SCART "or" DVI to RGB SCART
What I need, a cable? converter? something home-made?
Thanks in advance!!!
Bosse
Hev you seen this?
http://www.idiots.org.uk/vga_rgb_scart/
You will find more effective wiering on
http://www.nada.kth.se/~feldt/vgascart/lodning.html
The text is in swedish though
Username: Momo2oo2
Thanks Bosse!
yep i already knew the first web, but my soldering skills are null ^^ (and that statement in red at the beginning of the page scares me; if the dead one is my radeon its ~150€, but if its my TV its a LOT more)
So what I wish to find is an buy-and-plug cable/adaptor
Anyway, Ill try to ask a friend of mine to make the soldering.
BTW, anyone know of a swedish/english transate web? ^^
Thanks!!
Beto
i have a DCT with a nine pin VGA output and an HDTV with a DVI input is getting a VGA to DVI converter worth it? and which would be better DVI-I or DVi-D?
Username: Clareygirl
what scart lead do i need to connect my freeview set top box to my Phillips TV/Video combi? And also to connect my DVD player to the whole set up aswell? PLEASE HELP!!
