Cinema 6 codes URC-6800b00
Joey
Does anyone have the product codes for the cinema 6 remote control?, or is there a site to get them?. cuz I've lost mine.
You can e-mail me at Fordblue@www.com
Thanks
Joe
eCoustics
Use this link at the oneforall.com web site.
http://www.oneforall-int.com/ussite/northamerica/products/urc/premiumline/URC_6800.htm
Then click "Find Your Code".
I need to replace a remote control for my Pioneer DVDC603. This model player has a random play button on the remote only. Where and what type of remote can I find to replace the unit that came with my player? I like the ramdom play feature for DVD's and CD's. I also have a remote from my Yamaha 5280, but it doesn't have the random play feature either. Why doesn't Pioneer have a random play feature on the face of the DVD/CD player? This seems strange.
tre 1
I have a Scientific Atlanta cable box from Comcast and can not program it into my remote. Are there any codes other than the ones in the manual?
