You hold down dvd then set up buttons until the light blinks twice. You then key in 991 then press power and dvd alternatively until the dvd turns off. you then press the set up button to store it.
What is the code for remote control if I have Maranz PDP 42(Plazma TV). The list in the Manuel is no good
