Coax Cable (RG6) question
Username: R0lsen
Wilmington, NC
Can you use RG6 Coax cable with RCA adapters on the ends for audio cables. I have bunch of RG6 cable and all my system cables (red, white, and yellow) are all cheap ones. So I thought I could buy a bunch of ends and RCA adapters and make my own cables, I might come end up with some quality cable instead. Any thoughts?
Lester
Short answer... Yes.
L.
Username: R0lsen
Wilmington, NC
Thank You. Since my post I have found a good web site on how to do just that.
http://white.hometheatertalk.com/diycable.htm
Lester
Yup! The canare route would have been in the slightly longer answer. And although it's a good system, it's also a bit pricey for a couple of cables.
If you are going to spend that kind of money, I would suggest using RG59, solid copper coax w/braided copper shield instead of RG6.
L.
Username: R0lsen
Wilmington, NC
Not sure if I'm going to follow that web site exactly, but something along those lones. I will be using RG6 cable since I have about 150ft left over from another job. Thanks
