Non bi-wireable 2 way speaker control box
Username: Kperry
Does the use of a B Tech 2-way speaker control unit compromise, in any way, the quality of sound emanating from either the amplifier or the speakers? If so, is this only when running 2 sets of speakers simultaneously?
Also, the B Tech 2-way speaker control unit that I have does not house banana plugs. The problem is that one set of speakers I own has banana plugs on the speaker cable. If I remove the banana plugs from said speakers, so that the 2-way speaker control unit can house the cable, will this, in any way compromise the quality of sound emanating from either the amplifier or speakers?
