Glossy sheen on LPs
Username: Cockneyone
Sebring, Fl United States
I have several LPs that are VG++ but lack that glossy sheen that one finds on LPs.What do I need to restore these to a shiny finish?
Username: Two_cents
Post Number: 771
If the loss in gloss is due to dirt, dust and crud on the record, then a wet cleaning should do the job. Google "wet cleaning lp" or some variant to find different cleaning methods.
Usually a lack of sheen is due to record wear, which can't be fixed. If you say your lps play VG++ then I don't think this is the case.
