What amp(s) should I hook up to my 2 15" Visonik 1500watt rms Compettition subs to get the most out of them?? And what kind of box?? Thanx!!
Visitor#78
Yo Nick. How about taking your Visoniks to the local flea market and getting them off your hands. Then ask what kind of amp you can use to power some REAL subs.
i am going to buy 2 kicker l7 15's and i would like to know if i should get the 2 ohm or the 4 ohm also which amp and if they should be in a sealed or ported box. thanks
