Question about Mach audio system...
Username: Ruffhouze
I am soon to be getting a 2000 Mustang...
Thing is, I have no idea how to tell if it's got the Mach audio system or not...There's a tuner/tape deck, and then there's the cd deck below it...
I want to replace the tuner deck with a new alpine one, but when I try to order on crutchfield, it reccomends the adapter to use with the mach system...
Is it worth getting the adapter to use with the factory amp or just bypassing it?
Username: Jarryd2018
Post Number: 25
i was wonderin the same thing but i have an explorer and i didnt kno if i had the mach audio system
Username: Joe718
Brooklyn, NY
Post Number: 130
it all depends if you really want a hard hittting sytem or not. the mach system sounds good but if you want to go to that next level of clearer louder sound, i would say bypasss it
