Help finding an amp
Username: Nysteelers
ok ive been reading up on this stuff and am starting to learn, but what do you think a good multi-channel amp would be? for under 325 shipped.
..and correct me if im wrong, but multichannel means you can hook up subs and speakers and all that...unlike mono where you can just hook up one thing?
Username: Davids2004
Houston, TX USA
Post Number: 667
I would go with a 4 channel amp. That would allow you to run two subs and a set of speakers or one sub and a set of speakers. Look on ebay and type in 4 channel amp and you will get alot of choices.
good luck.
ok thanks..how is this one http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38638&item=791 7921347&rd=1
or this one..http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38638&item=791 7642877&rd=1
both are 4-channel...so after that i would find a pair of subs and some speakers and im all set correct?
Username: Jayj
Louisiana USA
Post Number: 437
I would look for a better amp then both of those. Good Luck
Post Number: 7
alright....would a 2 channel amp be enough for 2 12 inch subs, and door speakers...or would i need a 4 channel amp?
Username: Jayj
Louisiana USA
Post Number: 445
I myself would run a large amp for the subs such as a mono amp. And run a smaller amp for the door speakers. What kind of subs and speakers are you using and what is the RMS value of each?
Post Number: 8
well a friend recommended 2 alpine SWR-1241D subs seen here, but im still not sure bout the door speakers
http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=SWR-1241D&p_category=7 0&p_subcategory=150&p_main=10&p_more=y
and your talking about two seperate amps, 1 for the subs and 1 for the speakers?
Username: Jayj
Louisiana USA
Post Number: 448
Yup 2 amps. The alpines I would throw that idea and look into 2 12" Cerwin Vega V-max. For the amp a JBL 600.1. For the door speakers check out a set of Infinity components. The subs can be picked up here for about 180 bucks shipped.
www.onlinecarstereo.com
For the JBL you can do a quick search on the net and pick one of those up for about 250 shipped.
The components can be had here.
www.acaraudio.com
Good Luck
Post Number: 9
ohh nice ..thanks alot man....1 more question though... because i cant install all this myself..how much would a shop typically cost 2 install this?
