Where can i find V-maxx and CompVr vs. V-Maxx
hello wilber
im looking for either 2 12" vmax's or 2 15" vmax's....also which is louder vmaxx or kicker comp vr
Username: Symplestiles
Stockton, CA Usa
Post Number: 61
acaraudio.com has both brands of subs at great prices. in my opinion the vmaxs are a better sub, depending on your price limit/car space/money to spend on the amp will determine if you want 2 12's or 2 15's
Username: Caraudiofng
Houston, TX
Post Number: 121
Check www.onlinecarstero.com
2x12" VMax for $178 Shipped
2X15" Vmax for $230 Shipped
Those are both the 4ohm SVC models
Vmax is a better sub.
FNG
Spl Crack Head
what about this package but for that amount of money what you think bout it...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32822&item=5716645176&rd= 1
The Infinity Reference is their bottom of the line sub.
Also, those are 300w RMS each per sub.
That amp is only putting out 343w RMS total wich is only 171.5 per sub. Not that great of a deal because the amp isn't powerful enough for both subs. You'd be better served with the suggestion above
