Is this box worth it?
Username: Purplehase_bong
Bc Canada
Post Number: 149
its a dual 10"Upload
Bc Canada
Post Number: 150
the guy is asking $70 canadian
Bc Canada
Post Number: 151
and he says its bandpass :S im confused! it looks like a seald box to me
Username: Koz1031
Monticello, In United states
Post Number: 33
get a picture of the back side maybe that's where the ports are. Other than that it's a sealed box.
Bc Canada
Post Number: 152
if the backside has ports wont it be a vented enclosure?
Username: Insearchofbass
Post Number: 115
bandpass boxes have their chambers in front of the woofers and i dont think its ported on the back they usually port on the top or front looks like sealed with a plexi window. Also make sure that is thick plexi otherwise it will flex and cause lost spl and such.
thanks,
in search of bass
Username: Jessejames
NB, PA USA
Post Number: 107
yeah, that doesn't look like a band pass... the subs them self are usually 'inside' the box with a sealed chamber infront of them, then ports on the top or front, i think you could find a better deal on that, it's basicly a sealed box... even if it has ports in the back... probably not worth it.
Bc Canada
Post Number: 153
doesnt it look like a pro box? it has double 3/4 MDF and corbon fiber front. umm so i shouldnt buy it? i want more bass then my bandpass puts out. the bandpass only play one note. u guys should save the pic and enlarge it to see the carbon fiber front
Post Number: 135
your right it is a double .75 i missed that. I dont know if its bandpass im on my friends pc so i cant download the pic right now.
thanks,
in search of bass
Post Number: 136
looks sealed to me
Bc Canada
Post Number: 154
man i bought the damn thing and it isnt nearly as bassy as the bandpass :-(
Bc Canada
Post Number: 155
hmmm i was thinking of putting the jl subs back in the bandpass box and wiring them to 2 Ohms and adding a 12" jbl gt in a ported box at 4Ohms. so one channel is gonna be 2ohms and the other 4ohms. can it be done on a 2 channel amp?
Bc Canada
Post Number: 156
u guys are slow.!
Username: Jmloughrey
Farmington, CT
Post Number: 188
i dont see a reason why it wouldn't be able to do it...your amp may not be very happy with it but it'll give you bass...
