Bronze Member Username: JessejamesNB, PA USA Post Number: 52 Registered: Aug-04 | I have an oppertunity to buy 2 15" Kicker Comps Low Profile 15" box Audiobahn a1801 amp price tag... $375 for everything I only have a few day window to buy it, so i was looking for input from you guys, is it a deal? |
Silver Member Username: JmloughreyFarmington, CT Post Number: 170 Registered: Jul-04 | do you have the specs off hand on the amp, i have the audiobahn A8002T, i got a great deal on the amp and it powers my Kicker L5's nicely, its ashame i'm looking to sell it, anyone interested? |
Silver Member Username: Sploosh56Post Number: 365 Registered: May-04 | I'd buy it. I have the 15" Kicker Comp subs also and they pound. |
Bronze Member Username: JessejamesNB, PA USA Post Number: 55 Registered: Aug-04 | Are they the Comp vr's the new comps or the older comps? Because the system i have now (2 12" Polk GNX on a Bazooka amp) i can sell... and it will make me more than enough $$ to buy the kicker package. I just want to make sure i'm getting a deal on things before i go selling all my stuff... I've heard good things about them, so i just want to make sure that it is an upgrade instead of a ripoff |
Bronze Member Username: JessejamesNB, PA USA Post Number: 56 Registered: Aug-04 | also... does anyone know if that amp is sufficent to run a pair of 15" kicker comps??? it's an Audiobahn a1801 |
Bronze Member Username: JessejamesNB, PA USA Post Number: 59 Registered: Aug-04 | stats on that amp http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13497 |
Silver Member Username: JmloughreyFarmington, CT Post Number: 176 Registered: Jul-04 | Go with an Audiobahn A8002T amp, its the amp i got, it'll put 400rmsx2 @ 2 ohms, or 200 x 2 @ 4 or 800x1 @ 4ohms RMS....its a great amp, your 15's are 250watt rms, so run them on there own channel at 4 ohms, that amp runs really cool, its got an intake fan that actually works, i've only sent the amp into protection mode once and i ran my system really hard for a good 45 minutes, http://www.sonicelectronix.com/item_73.html If the link doesnt work www.sonicelectronix.com Audiobahn A8002T $200ish Shipped The amp itself is 179.99....its a nice amp |
Bronze Member Username: JessejamesNB, PA USA Post Number: 64 Registered: Aug-04 | no see the thing is... i'm buying this as a package, and i'm getting everything for $375... the amp will be aprox. $150... and i don't buy over the net... |
Bronze Member Username: JessejamesNB, PA USA Post Number: 65 Registered: Aug-04 | I'll bridge them to 2 ohms on the mono amp... |
Bronze Member Username: JessejamesNB, PA USA Post Number: 66 Registered: Aug-04 | Though... the one wierd thing is why is the a1801t so much more expensive than the a8002t retail? |
Bronze Member Username: InsearchofbassPost Number: 99 Registered: Jun-04 | are you talking comp cvrs? or standard comps? thanks, in search of bass |
Bronze Member Username: JessejamesNB, PA USA Post Number: 92 Registered: Aug-04 | standard comps. |
Silver Member Username: InsearchofbassPost Number: 102 Registered: Jun-04 | if that means c comps they are ok and can use small boxes but im not sure what the amp is worth considering its all used prob not alot actually i prob wouldnt buy it at all if it was me. you can buy the comps cheap and that audiobahn amp is low on the power for the money. thanks, in search of bass |
Bronze Member Username: JessejamesNB, PA USA Post Number: 94 Registered: Aug-04 | Well i 'am' buying the subs for cheap, about 125 for the pair, and i'm buying the amp for about 150... |
Silver Member Username: InsearchofbassPost Number: 106 Registered: Jun-04 | read the triva area i replied to you there jesse thanks, in search of bass |
Silver Member Username: JayjLouisiana USA Post Number: 422 Registered: May-04 | Its a pretty good deal Jesse go for it. |
Bronze Member Username: JessejamesNB, PA USA Post Number: 99 Registered: Aug-04 | yeah, i just hope it's worth all the work with totally switching things out and such... if i can get my stuff sold... i'm good |
Silver Member Username: InsearchofbassPost Number: 111 Registered: Jun-04 | jesse dont switch the polks out to keep the kickers it isnt going to be as loud. They are entry level kickers. I thought you were keeping the polks too. thanks, in search of bass |
Silver Member Username: JessejamesNB, PA USA Post Number: 103 Registered: Aug-04 | I revert you to my post in the trivia thread...:-) |
