Good setup?
Username: Nihil
I want to get new subwoofers and I've maybe settled on getting 2 15" kicker cvx and a Rockville dB16 8000 Watt Peak/2000 Watt Dyno-Certified RMS Mono 2 Ohm Amplifier Car Audio Amp.
My goals were to get the loudest, deepest, and lowest setup with my budget of $1200. Are these a good choice for my goals or are there other cheaper or better subwoofers and amps I can use? I enjoy listening to it often so I need it to be sturdy and last a while. Also is there anything I should be aware of or percautions i should take when drawing high ammounts of power?
Username: Joe1234
Post Number: 2071
Yes there is far better equipment for the price, far far better.
Need to Register?
Forgot Password?
Enable HTML code in message
