Sundown sa8
Username: Kennyhammond
Wanting to run one 8 in my 2002 single cab Silverado is there a box too buy for it or does it have to be a custom made. Then want a box for one 10 SA for my crewcab 2012 Silverado or just do the probox loaded
Username: Bernymac
Phnom Penh Cambodia
Post Number: 4916
You'll need a custom box made for your 02. If the probox box has the required mounting depth that the sa-10 requires then you'll be fine. But its always best to use custom boxes for these subwoofers so that you'll get the most out of them.
Need to Register?
Forgot Password?
Enable HTML code in message
