Do I really need a LOC?
Username: Drax
Hi guys tomorrow im getting my Sub and amp installed on my 2019 F150 XLT Non Sony, just stock 8" screen with sync 3, (hertz hcp 1dk, and alpine type R 12) the install guy said that he suggests to install a LOC for 60$ and says that its strongly recommended to clean up the Bass Roll Off, and flatten the frequency before the amp . Do I really need one? I believe my Amp already has Hi Speaker Levels and i was thinking to just tell him to tap into the front speakers to avoid buying the LOC will that work? Or should i purchase it for 60$? My other question is do i need a line-in converter? or is that the same thing as a LOC? Thanks guys
Username: Dkosuj
Uskudar, Istanbul Turkey
I see individuals notice getting a LOC to reestablish the bass since the stock unit EQ is crap. What occurs in the event that I don't utilize a LOC? Will I simply get not as great bass?
Need to Register?
Forgot Password?
Enable HTML code in message
