Amp Problem
Username: Brandons2697
So I've had my subs for about a year now, and recently my amp started cutting out and now it doesnt turn on. If I reconnect everything, pull all the fuses out and put them back in, the amp will power up and immediately shut off. I don't know what is causing this. I have my turn on wire under my accessory fuse. That fuse is good. I checked by using that fuse in another slot and it works fine. My ground is connected to my chasis in a pretty good spot. I also put my amp in my brothers car and it worked perfectly and we have the same set up. What are my possible problems?
Need to Register?
Forgot Password?
Enable HTML code in message
