Units With SD Input
Username: Javid2099
This is my first post here, since I don't know where else to go. I'm looking to replace my factory head unit with something better.
I'm looking for a stereo that takes SD card as an input. Everywhere I look there are units with USB input, but I don't want a USB stick always sticking out, since it looks awful. Are there any models that you guys would recommend that have SD card capability? I've also heard that there are units with rear USB capability, that would also work I guess.
Username: Illuminator
Post Number: 5123
SD card compatibility is going to be extremely rare, and I actually have only seen it in a few units, none of which I can think of at the moment.
In any case, getting a unit with a rear USB is definitely the best way to go. I also don't like how the USB would stick out on the front (and from a technical standpoint is vulnerable to someone hitting it and messing up the USB or head unit). Most nicer head units have rear USB inputs anyway.
Username: Hay88
Post Number: 677
Javid2099
MOS (Ministry Of Sound) CAR RADIO have SD card capability.
Username: Javid2099
Jexx, would you happen to know of any good models with rear USB input that I should look at? I know Pioneer has some, but I can't seem to find any at the moment...
Post Number: 5128
Sure. I don't know what your budget is, but I'll list a few so you can get an idea...
Alpine CDA-105: http://signature.crutchfield.com/s_500CDA105/Alpine-CDA-105.html
Alpine CDA-117 (I'm fairly certain this has rear-USB, not 100% sure): http://www.alpine-usa.com/product/view/cda-117/
Clarion CZ500: http://www.clarion.com/us/en/products/2010/audio/source_units/cd/CZ500/us-en-pro duct-pf_1259392953332.html
Pioneer DEH-P4100UB: http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players /DEH-P4100UB
Pioneer DEH-P7100BT: http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players /DEH-P7100BT (there is also a Premiere edition--the DEH-P710BT)
Best bet is to just google the car audio brand you want with 'rear USB' i.e. "Alpine rear USB" and you'll see several options.
Username: Stripes
Nebraska United States
Post Number: 7
Rear USB? Why is this any better than front USB? I understand you can run a USB extension cord from the rear, do you seriously think you're gonna put a USB stick in the back of the unit, then put it back in the slot? Or I must be missing something here...since you folks are saying rear USB is better...?
Post Number: 5369
Nic: that's exactly the point. You can use an extension cord and run the USB port to wherever you want, preferably out of sight rather than having the USB protrude from the head unit (it's more of an aesthetics thing).
And yes, I'm quite certain nobody is planning on sticking their hand around to the back to plug in their USB device
Username: Kiwi_39
Palmerston NorthNew Zealand
I brought a 2010 Panasonic CQ-VW220W latest model head unit (double din) that has rear USB input, but has a long cable with the connector so you just plug in the USB stick and away you go. This sits in my glove compartment nicely out of the way.
Username: Hmichaelr
Adams, Tennessee United States
Alternatively, you can buy a head unit with rear USB input and plug a hub into that which allows you to input a variety of storage devices and place them somewhere out of harm's way. I found this one on Amazon: it's inexpensive and versatile. I can't vouch for quality because I don't own one (yet). Here's a link: https://www.amazon.com/Hapurs-Portable-USB3-0-reader-Switch/dp/B00KZEAR9A
Need to Register?
Forgot Password?
Enable HTML code in message
