New member Username: ThbatsPost Number: 6 Registered: Jun-15 | help me radio code renault philips model : 22dc594/62s prod no :fdo497298077135 |
Gold Member Username: IwosPost Number: 1273 Registered: Jul-14 | thbats New member Username: Thbats Try .. 7663 |
New member Username: ZencraPost Number: 1 Registered: Jun-15 | Hi could you please help with code for X945 Cheers |
Gold Member Username: DeksterPOLAND Post Number: 2218 Registered: Sep-12 | Craig CODE 2088 contact me: http://koddoradia.pl/ |
New member Username: ZencraPost Number: 2 Registered: Jun-15 | thank you so much |
New member Username: IamcassiejonesPost Number: 1 Registered: Jun-15 | Hello I need some help I need a car stereo code for my Renault Clio Any help would be hugely appreciated Philips radio 22DC481/62 FD1099079116020 7700433070K755 Thank you Cassie |
Gold Member Username: IwosPost Number: 1279 Registered: Jul-14 | iamcassiejones New member Username: Iamcassiejones Hello, TRY CODE .. 4543 |
New member Username: IamcassiejonesPost Number: 2 Registered: Jun-15 | Thank you for your reply. Unfortunately that code did not work |
Gold Member Username: IwosPost Number: 1280 Registered: Jul-14 | iamcassiejones New member Username: Iamcassiejones See Instructions > http://www.dndservices.co.uk/renault-22dc481-62.html |
New member Username: IamcassiejonesPost Number: 3 Registered: Jun-15 | When enter 4543 it just says CODE. |
Gold Member Username: IwosPost Number: 1282 Registered: Jul-14 | iamcassiejones New member Username: Iamcassiejones RENAULTS WITH RADIO STEERING WHEEL CONTROLS Switch Radio On - Display Shows 'CODE' quickly followed by " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For FIRST Correct Digit displayed Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For SECOND Correct Digit displayed Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For THIRD Correct Digit displayed Press " ¬ " On The Stalk Control To Enter Rotate Thumbwheel " For FOURTH Correct Digit displayed If the correct code number is now shown on the display Press And Hold " ¬ " Until A Beep Is Heard (typically 3 seconds) |
New member Username: IamcassiejonesPost Number: 4 Registered: Jun-15 | Have used instructions but still goes back to aCODE. Thank you though |
New member Username: VasilikiPost Number: 1 Registered: Jun-15 | Could you please help me unlock my car radiocassete player. The mechanic changed the car battery and now my radio asks for a code. RENAULT RADIOSAT 6010 7700 433 074 B522 PHILIPS 22DC461/62E 9022 214 61622 |
Gold Member Username: IwosPost Number: 1287 Registered: Jul-14 | vasiliki New member Username: Vasiliki try code .. 0495 |
New member Username: VasilikiPost Number: 2 Registered: Jun-15 | ALMEIDA Thanks for the quick reply. I will try it when display on the screen 0000!!! |
New member Username: Magpie1984Post Number: 2 Registered: Jun-15 | Need code for megene Rn279f20178329 22dc279/62t 7700434423tn966 Thanks for your help |
Gold Member Username: IwosBR- Gloria Post Number: 1302 Registered: Jul-14 | Theduffman New member Username: Magpie1984 Duplicate post....Already answered |
New member Username: McarragPost Number: 1 Registered: Jun-15 | Hello. Can anybody please help me with my Renault radio code? The serial number is: 8200089153TS789 Thank you in advance! |
Gold Member Username: IwosBR- Gloria Post Number: 1303 Registered: Jul-14 | Carra New member Username: Mcarrag Hello, TRY CODE .. 7223 |
Platinum Member Username: RegroosterPost Number: 11797 Registered: Aug-08 | Renault codes and info available here 24/7...No waiting ukbookshelf.co.uk/renaultweb |
New member Username: McarragPost Number: 2 Registered: Jun-15 | Thank you Almeida, but the code you kindly provided me didn't work. I see ERROR on the dashboard and I attach herewith a picture of my autoradio codes hoping it would offer more clue. I own a 2004 Renault Espace. Any hint? ![]() |
Gold Member Username: OpelopPost Number: 2507 Registered: Sep-12 | Carra New member Username: Mcarrag add all serial numbers from tuner contact to me radiocodeservice@gmail.com |
New member Username: LupusPost Number: 1 Registered: Jun-15 | Philips PHAPCFT9017442 22DC722/65 90222172265900 00196169017442 PHC9017442 I agree with the turkey, please can you help? Thanks. |
Gold Member Username: OpelopPost Number: 2509 Registered: Sep-12 | lupus New member Username: Lupus code 5126 contact to me radiocodeservice@gmail.com |
New member Username: LupusPost Number: 2 Registered: Jun-15 | thanks |
New member Username: CismileanuPost Number: 1 Registered: Jul-15 | pls help whith a code for Mode No: 22dc269/62t t0j116 8200205833tj116 |
Gold Member Username: DeksterPOLAND Post Number: 2258 Registered: Sep-12 | Cismileanu CODE 7794 contact me: http://koddoradia.pl/ |
New member Username: CismileanuPost Number: 2 Registered: Jul-15 | thanks !!! |
New member Username: SallamPost Number: 1 Registered: Jul-15 | I've recently had to disconnect the battery in my mega be the code that's in the book is incorrect the serial number is 8200607918TP186. The code in my paper work is 9008 and it says error every time I enter this |
New member Username: SallamPost Number: 2 Registered: Jul-15 | Megane * |
Gold Member Username: IwosBR- Gloria Post Number: 1362 Registered: Jul-14 | Sallam New member Username: Sallam try .. 0895 |
New member Username: BurazPost Number: 1 Registered: Jul-15 | Hi, can you help me? Need code for laguna TOP454 RNRD0130012710 |
Gold Member Username: DeksterPOLAND Post Number: 2267 Registered: Sep-12 | burx CODE 0565 contact me: http://koddoradia.pl/ |
New member Username: BurazPost Number: 2 Registered: Jul-15 | thanks Dekster |
