Peugeot expert radio code
Username: Bramble1234
Hi guys,
I have just replaced the battery on my van and you guessed it no code for the radio.
Model pu-2294A©
Sn Cl040140945370c
I have looked around other sites and tried various ideas. Im now on my 5th attempt, so any help would be greatly appreciated.
Thanks.
Username: Titanum123
Post Number: 1240
bramble1234
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
contact me: dekcode7@gmail.com
These are the only numbers I can locate on the radio. Are any of these the ones that I need?
Thanks once again.
Post Number: 1241
bramble1234
sorry we can't help
Main Dealer or a Decoding Service only for this code
Cheers anyway. very muh appreciated.
