Ford 6000CD - CODE
Username: Astragsigsi
Aalborg, Nordjysk Denmark
Hello. Need code for Ford 6000CD
Part Nr: 8C1T-18C815-AC
Serial Nr: V010694
Model Nr: SINGLE CD - GGDS
Any help is appreciated!
Thank you in advance.
Username: Iwos
Post Number: 117
Dimitar
Hello,
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Username: Danielalb
I have contacted the ford company in my country and they told me to pay nearly 30$. can you provide me a link where i could ask to the fordcompany the code for free.
I am looking forward for a answer from you.
Thanks in advance
