Jensen Parking Brake Bypass VX4010 VX4020 VX7010 VX7020 VX3010 VX3020
Username: Countdemonet
Who can advise the parking brake bypass codes for this series of Jensen Mobile Multimedia units? I have the VX4010. Also how do I get to the hidden menu (if there is one). Not interested in the wiring, relay, after market pulser tricks YET. Just the codes if any. Thanks!
Username: Bewing
The brake works off of a switched ground. I simply connected the brake wire from the radio to the radio chassis. There is usually a screw or two on the back of the radio you can connect the wire to. Works perfect.
Need to Register?
Forgot Password?
Enable HTML code in message
